Home › Forums › Troubleshooting › Duplicate MAC with Different IP addresses in Connected Devices (RTSP camera)
  • This topic has 3 replies, 3 voices, and was last updated 3 years ago by trust_in_wrt.
  • #5881
    trust_in_wrt
    I have an RTSP video camera on my Wifi network and have assigned it a static IP. It shows once in the Hostnames and Static Leases table. However, it shows twice in the Connected Devices list — the MAC address is the same, but the IP address is different.
    I have custom code that is directly using the correct IP address (static) so I don’t want the camera switching to the other IP address if it disconnects or the router reboots. I also have another identical camera that does not have this duplication problem. How do I remove the invalid entry in the connected devices list?
    #5884
    @trust_in_wrt Usually the invalid entry will go away in a few minutes. Are you still seeing it?
    #5885
    trust_in_wrt
    It was stuck for weeks after last firmware update. I updated to latest firmware and rebooted. All is okay now. Thanks.
