Home › Forums › Miscellaneous › How to test my max internet bandwidth usage
  • #6702
    Echo
    Is there a way to use the router (AX1800)’s features to figure out what my max bandwidth usage is so I can determine what internet speed I need from my ISP?
    #6705
    It doesn’t monitor your maximum bandwidth usage. But you can use the bandwidth throttling function under Access Control to clamp down the max bandwidth and see if it affects your online experience.
    #7024
    Rocket88
    Your best bet to determine you max internet speed is to connect a PC that has ethernet directly to your cable modem or optical network tranceiver (ONT) and run a speed test from the computer. To get the most accurate results reboot the computer and then be sure the speed tester is the only program running. If using a browser based speed checker be sure there is only a single tab open.
    Best to try a few different speed checkers.
