Home Forums General Configuration Parental control: minimum configuration
  • #146
    By default, parental control is disabled:
    Parental Control Disabled
    To enable parental control:
    1. Click the Enable button
    2. Leave “Safe Search”, “Block literal IP addresses”, “Block proxy, VPN, TOR” checked
    3. Select OpenDNS Family Shield or OpenDNS Home from the DNS Servers dropdown.
    4. Click the Save button.
    Enable Parental Control
    Result:
    1. Web contents filtered through OpenDNS.
    2. Safe search enabled.
    3. DNS bypassing techniques blocked.
    4. Proxies, VPN and TOR bypassing blocked.
    5. All devices in your wifi network follow the same policy.
    Once you are familiar with the minimum configuration, you can create additional profiles for more more flexible controls.
    • This topic was modified 10 years, 9 months ago by pcwrt.
    #4880
    aaronc1975
    Hi! I’ve just bought your Toronto-N router. However, there is no Parental control settings. Please assist me.
    #4881
    aaronc1975
    Nevermind. Once I connect the WAN, the Access-Control (not Parental control) settings appears in the Apps.
