Changes included in this update (v1.27):
- Added WiFi client isolation option to guest wireless network.
- Added more VLAN options (X1, X2, X3 in addition to LAN and Guest) for Ethernet ports.
- Added Ad Blocker. You can now block ads for a profile by checking the “Enable Ad Block” box.
- Added functionality to temporarily extend WiFi time without changing WiFi schedule, from the remote management interface.
- Added system configuration restore option to restore only Access Control settings, from the remote management interface.
Incremental update v1.27.1 included:
- Fix to a bug that caused malfunction when Access Control is turned off at router level.
- Fix to a JavaScript error when all NTP servers are removed from System Settings.
This topic was modified 7 years, 6 months ago by
pcwrt.
