Home › Forums › Announcements › pcWRT firmware v2.8.8 Release Notes
Viewing 1 post (of 1 total)
  • #7292
    Change password was broken in v2.8.7, so you want to update to this version if you’re on v2.8.7. This release supersedes v2.8.7, which means if you rollback to a previous version after updating, you’ll rollback to v2.8.6.
    Updates in this release:
    1. Bug fix: change password was broken in v2.8.7
    2. Improvement on ad-block list downloading
    3. Add Vendor ID and Client ID options to DHCP Internet connection
    1. Have your configuration backup ready. Create a backup file for your current configuration, if you don’t have one.
