Home Forums Parental Control Time Limit for a specific site
Viewing 13 posts - 1 through 13 (of 13 total)
  • #2077
    Can i set a time limit for a specific site? For example, maximum 30 minutes a day for “facebook.com” etc…
    #2078
    Example: Facebook is accessible from 8:00 pm to 11:00 pm, but in this time range i can use it only for maximum 30 minutes, 1 hour etc…
    On android, there are much applications that can do this, i use AppBlock for this.
    This function is really important.
    #2082
    It’s a good thing to have if you can accurately account for the time spent on an app or site. However, this is hard to do on the router. Because the router only sees network traffic, it doesn’t know whether an app was actively used. The Facebook app has a lot of background activities, so tracking usage at the router can easily over count time spent.
    An app on the smart phone itself, however, can see when Facebook is actively used.
    #2084
    Is not possible to implement this feature in a future firmware version? It would be a great time control for kids.
    • This reply was modified 8 years, 1 month ago by Casino.
    #2088
    It’s a challenge to account for active usage at the router. More likely than not, you end up over counting usage and annoy the child, which might lead to disputes.
    Our general advice is, instead of monitoring a child’s every move, parents should spend more time communicating and building trust. Technology can only play a secondary role. Our initial motivation for building this product was to make parental control less restrictive, not more. We wanted to build something parents love, but children don’t hate.
    #2092
    Yeah, but i have a problem if my son spend more than 1 hours a day on facebook at my home pc when i’m not at home. I can not control it unfortunately. I haven’t this problem on his smartphone because i can set limit time there.
    Set limit time on site like instagram or especially youtube (listening music at night when we sleep) would be a great thing to implement on the router.
    For this reason many developers have create app like “StayFocus” “Appblock” and hundreds like that, only for to solve this problem.
    Thanks anyway.
    #2093
    Implement this feature in your router would make it the best one in the world, i think.
    #2100
    @casino Thanks for the advice. We understand the need and will keep that in mind.
    #2740
    Can you implement this please?
    Would be really great to have this option.
    #2742
    @casino Thanks for the suggestion. We won’t be able to implement this in the short term. In the meanwhile, you may try some workarounds.
    For example, if it is possible to schedule a one hour window for some sites, create a calendar with a one hour window. The child will only be able to access those sites within the scheduled window.
    If on-demand access is desired, you may create a calendar with no allowed time slots. So normally, the child won’t be able to access the sites. When access is requested, you can use the Calendar time extension function to temporarily allow access for the desired amount of time.
    #2744
    Thanks. Waiting for this update.
    #2893
    There are news for this?
    #2898
    @casino Due to the technical complexities involved in accurately accounting for active usage time (vs. background network activity), this is not actively worked on currently. We’ll update here if the status changes. Thanks!
