Home Forums Troubleshooting Unable to login after firmware upgrade
  • #7150
    koningskruid
    Today 2026-01-31 I upgraded my firmware 2.7.6 to 2.8.6 on my pcWRT PW-AX1800.
    I can not login to the router, it comes with the page http://10.159.158.1/cgi-bin/pcwrt/anon but neverthless it says that it runs 2.8.6. This page has two “buttons” and tells me my ip is 10.159.158.220
    My computer had always permanant DHCP 192.168.10.220.
    I can connect to internet. Other computers, swiches and access points on my network are not reacheable.
    I do not have the firmware image 2.7.6, and even if I had it, I can do nothing as I have no user interface to the router.
    $ssh 10.159.158.1 gives “connection refused”
    So what to do now ?
    #7151
    Your computer connected to a different VLAN, i.e., no longer on “LAN”. That’s why you’re getting an IP address like 10.159.158.220. By default, devices on these other VLANs do not have the permission to log in the router.
    Connect your device to an SSID on “LAN” or connect it with a cable to a port assigned to “LAN”.
    #7153
    koningskruid
    Thanks for the message.
    I had VLAN “LAN” and VLAN “X1”. The firmware upgrade was done on a computer in LAN. Do not think it is a VLAN problem.
    By resetting the router with the reset button (pinhole) in the router, I came in an “intital setup screen” but still firmware 2.8.6. From there I could re-enter and validate all settings among others my VLAN config, but it took a while.
    It would be beneficial if the firmware is available on the downloads page.
