Home Forums Feature Suggestions VPN suggestions for configuring on the AX1800 in Wireguard protocol
  • #6638
    Echo
    I will subscribe to VPN service from Mullvad, IVPN, or Proton to be configured and run on the AX1800 in Wireguard protocol. Do you recommend one, or suggest that I avoid any of those, based on your experience with how they interact with AX1800 or other pcwrt routers?
    #6642
    All of these will work on the pcWRT router.
    #6644
    Echo
    Thank you. Is the “How to setup Mullvad VPN on the pcWRT router (WireGuard)” blog article from 4.5 years ago still accurate?
    https://portal.pcwrt.com/blog/2020/07/how-to-setup-mullvad-vpn-on-the-pcwrt-router-wireguard/
    #6656
    bolozinaction
    Mullvad ip address point to India
    most of those IP’s point to India even though it says its from Sweden.
    Probably Indians in Sweden running Mullvad.
