Coax–>modem–>AX1800–>Newfi D2 (AP mode)
AX1800 “sees” a computer ethernet connected to Newfi (on the connected device list), but not the Newfi, or any other Ethernet connected devices (tried a PS5).
AX1800 performing fine otherwise (found out the hard way that the LAN Ethernet port is left to right #3, unlike the Newfi)
I followed the instructions from the blog explicitly (I believe)
AX1800 running on v2.8.8
Newfi firmware unknown, I am not sure I updated to current, and I can’t verify it (login fail)
the blog instructions note to mirror the network SSIDs from the AX1800, which I did (both share the same LAN SSID, as well). I did add a fourth network SSID to the Newfi.
does the firmware need to match? thoughts?
appreciated
