Home › Forums › General Configuration › Bad Gateway Firmware Update/Cloud Management
  • #1404
    [email protected]
    Whenever I try and update the firmware OR try and enable ‘cloud management/Remote Administration’, I get a message after a little bit that states “Bad Gateway”.
    Any idea?
    #1406
    Did you enter email address when you performed the initial setup? If not, you can enter your email address in the System Settings page, in the “Backup/Restore Settings” section. Reboot the router after you enter email.
    Please let us know if email is there but you still have problems.
    #1426
    [email protected]
    Yes, my email is there. I’ve rebooted a couple of times but still can’t do an auto update or cloud remote.
    #1428
    Please send email to [email protected]. We need to gather more information to resolve this issue. Thanks!
