Home › Forums › Parental Control › Block Specific VPN
Block Specific VPN
  • #1974
    I want to block only specifi VPN, and not block all them checking “Block VPN, Proxy, and TOR”.
    Is it possible?
    #1975
    For example, i just want to block Opera (Opera Turbo that use Proxy) and Tor Browser.
    #1977
    Opera VPN should be blocked by OpenDNS already (if you choose OpenDNS). TOR cannot be separated from other VPNs. When you block TOR, you block all other VPNs. However, you can block all VPNs but allow the VPNs you need by adding the domain names in the “Allowed URLs”.
    #1978
    But if i want enable all VPN and just block a specific one? Can i do it?
    Maybe in a future firmware update?
    #1986
    You can block specific VPNs by adding the domain names in the Blocked URLs list. However, this cannot be done for TOR since the domain names cannot be determined. But if you block TOR, you will block all VPNs.
    #1991
