Home › Forums › General Configuration › How do I block a device on PCWRT
  • #7047
    w9yU34AC8yd2
    Dear experienced users/admin,
    I have a device on my network that I would like to block.
    Under Status menu, I can see the device under Connected Devices.
    Can someone help me with instructions on how to temporarily block it until I can find out more about it?
    Thank you.
    #7050
    Give the device a name on the Status page. Then you can create a profile under Access Control and assign the device to the new profile. Select White List for URL filter mode but don’t add any domains to the white list box. Check “Enforce Access Control” for the profile.
    You should be able to see all blocked requests coming from the device when you view logs from the Access Control page.
