Home › Forums › General Configuration › How to disable wifi for CenturyLink router
Viewing 1 post (of 1 total)
  • #335
    1. Connect your PC to the CenturyLink router with an Ethernet cable.
    2. Open a web browser, enter http://192.168.0.1 into the address bar.
    3. Enter Administrator Username and Administrator Password. Click Apply to login.
      * The default administrator username and password can be found on the sticker located on the bottom of the router.
    4. Click Wireless Setup.
    5. Click the Disable radio button.
    6. Click Apply to save your changes.
    7. Take a look at the front panel of the router. The WIRELESS light should be turned off.
