Home › Forums › General Configuration › Invisible SSID?
Invisible SSID?
  • #7489
    KnowsNothing
    For pcWRT AX1800, or in general:
    Is it possible to set up a WIFI network that does not advertise its existence broadly, but will still connect to devices that request connection with the proper credentials? This router – or any router?
    I played with with the “Disable SSID broadcast” option, using manual credentials entry on a phone, both before and after establishing a wifi connection (including “forget connection” between attempts), but was unsuccessful.
    I assumed that “Disable SSID Broadcast” meant “Stop Broadcasting SSID Name/Operation”, but my results seem to indicate that “Disable SSID Broadcast” really means “Turn Off/Make Unavailable SSID”.
    If possible, I would rather dedicate my devices to their respective vlans than have them fish around for any available networks, and would prefer not to advertise my vlans to passersby.
    Can I do this? If so, how?
    • This topic was modified 3 weeks, 1 day ago by KnowsNothing.
    #7493
    “Disable SSID Broadcast” meant “Stop Broadcasting SSID Name/Operation”, i.e., hide SSID. You should be able to connect if you know the SSID and password.
