Home › Forums › Announcements › pcWRT firmware v2.0.1 Release Notes
  • #3220
    Changes included in this update (v2.0.1):
    • Add port range support for blacklist/whitelist
    • Add partial domain name match to blacklist/whitelist
    • Add safe search for DuckDuckGo
    • Enable WiFi on/off for individual band
    • Add WireGuard and Strongswan VPN
    • Performance improvements
    • Add native DDNS support
    • Various bug fixes
    Follow us on Facebook or Twitter to get notified about new blog entries explaining the new features. If you have any questions, don’t hesitate to ask in our forums. Merry Christmas Everyone!
    #3221
    Thanks! So, as you said, waiting for the explaining of the new features, in particular the points 1,2,5,7.
    GREAT WORK! And merry Christmas to you!
    #3222
    Sorry, point 7 explained already, you’re great.
    #3223
    You forgot to write you added “Channel Width” in the wireless setting page too.
    I found “CleanBrowsing” and “CleanBrowsing (Silent) in the access control setting page. I searched in the cleanbrowsing official page but i have not found nothing about it. Can you explain it to me?
    • This reply was modified 6 years, 10 months ago by Casino.
    #3315
    Pullmanite
    Performed an Auto Update and no Internet access even after rebooting and resetting the router and cable modem. Modem is getting Internet, router is not. Any ideas?
    #3318
    Pullmanite
    Of course, I trusted in the update process and didn’t backup first, so now I’m hosed. Any chance I can get a firmware .bin of 2.0.1 or earlier?
    #3319
    @Pullmanite Please send email to [email protected]
    #3325
    How do i block partial domain?
    And port range? How it works?
    #3347
    @casino Will add some notes on this soon.
    #3348
    Version 2.0.3 released with some bug fixes. @casino You may want to update & test port forwarding again.
    #3358
    Added port range & partial domain blocking instructions here: https://portal.pcwrt.com/blog/2020/01/how-to-allow-or-block-web-sites-on-the-router/
    #3383
    How to set up VPN client & server on the pcWRT router: https://portal.pcwrt.com/blog/2020/01/a-router-that-talks-three-vpn-protocols/
