Home › Forums › Announcements › pcWRT firmware v2.4.6 Release Notes
  • #4992
    Changes included in this update (v2.4.6):
    • Add hardware acceleration for IPsec (TORONTO-AC, Newifi D2 models)
    • Restrict router management access by device name or user id
    • Add VLAN access control to VPN server configuration. If you have an existing strongSwan server configuration, you need to re-enable network access on the Server tab.
    • Add WireGuard client connection monitor
    • Add the capability to enter custom DNS over HTTPS (DoH) options (such as NextDNS)
    • Bug fixes for Access Control and VLAN configuration
    #4998
    Ramazanpour69
    Hi,
    Thanks for Notify.
    From where I can download the Firmware for mi 4c?
    there is 2.4.5 on /downloads page
    #4999
    Ramazanpour69
    I mean here:
    Downloads
    #5003
    The page has been updated.
    #5006
    Ramazanpour69
    Yes.
    I have upgraded to 2.4.6
    But I cann’t see Wireguard Monitor on Lite version!
    #5016
    @Ramazanpour69 It’s builtin, and runs automatically.
    #5018
    Ramazanpour69
    Thank you.
    Can you give me a command for Update the firmware from 2.4.5 to 2.4.6 via ssh without loosing the Data and configurations?
    #5022
    “Restrict router management access by device name or user id”
    What can you tell me about this?
    #5023
    @casino Go to the System Settings page, there’s a “Restrict router access” checkbox under Administration.
    #5029
    Minor update (v2.4.7): bug fix for a race condition when custom DoH service is used.
    #5056
    mrtao
    i have xiaomi 4c Stable Version.but i not upgrade to pcwrt
