Home › Forums › Announcements › pcWRT firmware v2.5.6 Release Notes
Viewing 1 post (of 1 total)
  • #5806
    Changes included in this update (v2.5.6):
    • Add function to schedule auto-reboot. If you want the router to automatically reboot, go to the System Settings page to set up schedule.
    • IKEv2 VPN performance improvement for CF-XR10. Previously the top speed for IKEv2 was 50Mbps, you should be able to achieve 250-300Mbps with this update.
    • Enhancements for WiFi startup.
    • Improvements for Internet access tracking and logging. Add calendar name in Internet logs page when a site is blocked by a calendar
    • Allow LAN side DNS server to be used on router (e.g., using a local Pi-hole).
    • Enhancement for adblock pause/resume controls.
    • Other minor bug fixes.
