Home › Forums › Announcements › pcWRT firmware v2.5.8 Release Notes
Viewing 1 post (of 1 total)
  • #5867
    Changes included in this update (v2.5.8):
    • Bugfix: domains inadvertently blocked when block TOR/VPN is checked
    • Bugfix: CF-XR10 LED for LAN not lighting
    • Internet access log raw mode rendering improvement
    • Allow white list override of implicitly blocked search engines
    • Avoid DoH fallback to unencrypted UDP/TCP mode
    This release supersedes v2.5.6, meaning, if you do a rollback, you’ll rollback to version v2.5.3.
