Home › Forums › General Configuration › pcWRT firmware v2.6.2 IMPORTANT!
  • #6249
    johnnyjackhammer
    After flashing with this firmware many settings were reset. One of the most critical may be that encryption for any existing WiFi networks has been disabled. Users should go through all of their settings and not “move on” after the firmware install.
    #6251
    @johnnyjackhammer Thanks for the feedback! What is your hardware model and what firmware version were you upgrading from?
    #6252
    johnnyjackhammer
    Thanks for your response. I was upgrading from the firmware version immediately before this version. pcWRT CF-XR11
    I had backed up before updating and after the updated I looked through and saw missing settings for Secure DNS, WiFi was completely reset to the default. I didn’t look for anything else and decided to use the backup to restore the settings instead of doing it manually.
The topic ‘pcWRT firmware v2.6.2 IMPORTANT!’ is closed to new replies.
