Home › Forums › Announcements › pcWRT firmware v2.8.5 Release Notes
  • #7109
    There are two updates in this release:
    1. Add remote management functionality for VPN
    2. Add mesh functionality for PW-AX1800 model
    1. Have your configuration backup ready. Create a backup file for your current configuration, if you don’t have one.
    #7113
    The firmware version has been bumped up to v2.8.6 for a hot fix to a bug that blocked the Status page in certain scenarios. If you are on v2.8.5, you can update again to get this fix.
    #7115
    Here’s how to set up mesh on the PW-AX1800: https://www.youtube.com/watch?v=_lIyd4BCsEQ
