Home › Forums › Announcements › pcWRT firmware v2.8.7 Release Notes
Viewing 1 post (of 1 total)
  • #7223
    Updates in this release:
    1. Add “monitor” option to Access Control. The “monitor” option logs Internet activities for devices but do not enforce profile settings.
    2. Add option to select ad-blocking block lists. Supported lists are EasyList, Hagezi Light, Hagezi Pro and Hagezi Ultimate
    3. Check CNAMEs in ad blocking
    4. Bugfix: country code support in VPN split tunneling
    5. Bugfix: apostrophe not supported in WiFi password for some models
    6. Bugfix: remove extraneous error messages in system logs
    1. Have your configuration backup ready. Create a backup file for your current configuration, if you don’t have one.
