Home › Forums › Device Setup (printers, IP phones etc.) › pcWRT SSID can not be found
  • #1540
    venfam
    We were using pcwrt router. Then husband somehow deleted the pcwrt SSID and it no longer shows up. I have reset the pcwrt router but the SSID no longer shows up in the available network list. Can you help me find the SSID please?
    #1541
    @venfam You can connect a PC to the router by wire and access the management console with http://192.168.10.1, or http://pcwrt/ (keep the trailing /). Then update the SSID and turn WiFi back on.
    If you need to reset the router, follow the steps here: http://portal.pcwrt.com/forums/topic/no-login-page-at-192-168-10-1/
    #1552
    venfam
    Thank you, problem solved.
