Home › Forums › General Configuration › Same SSID for 2.4 and 5ghz
  • #4368
    moral
    Can I name the same SSID on a 2.4 and a 5ghz band with the same pw where devices will simply connect to whichever signal is stronger?
    Thank you.
    #4372
    Yes you can. Name the bands differently gives you more control, but naming them the same is more convenient.
