Home › Forums › Device Setup (printers, IP phones etc.) › USB connected printer fails to detect
  • #3388
    salpta
    An HP Envy printer is failing to connect to the USB port of a pcWRT TORONTO-N v2.0.3
    Is the USB port enabled, or is there a check box I’m missing? Trying to determine if this is router problem or a printer problem. (BTW: yes, the printer works connected directly to a pc.)
    #3389
    The USB port is not enabled on the router.
    #3391
    salpta
    Thanks for the quick reply. Otherwise I’m very satisfied with this router.
    #4276
    LyonSanks
    Hi…I have seen this happen when the usb cable was conneted before the install disk asked for the usb cable connection to be made. Did you by chance hook the cable to the computer and printer before installing the program?
