Home › Forums › Parental Control › When parental control enabled no access
  • #560
    polevoym
    Hi
    I have a new pcwrt router.
    When I enable the parental control I’m not able to access any site.
    if I open cmd and do ping test I see I don’t get name resolving.
    what can be the problem?
    #561
    Is everything OK if you disable parental control?
    #562
    polevoym
    Yes, everything is OK.
    #563
    With parental control disabled, open a cmd window. Try these two commands:
    1. nslookup www.playboy.com
    2. nslookup www.playboy.com 208.67.222.222
    What are the outputs?
    #565
    polevoym
    C:\Users\miki>nslookup www.playboy.com
    Server: pcwrt.lan
    Address: 192.168.4.1
    Non-authoritative answer:
    Address: 185.31.17.65
    Aliases: www.playboy.com
    C:\Users\miki>nslookup www.playboy.com 208.67.222.222
    Server: resolver1.opendns.com
    Address: 208.67.222.222
    Address: 146.112.61.106
    #566
    polevoym
    I found my problem.
    I had also K9 enabled on the computer and the blocking for proxy was enabled in the parental control.
    This blocked the access.
    When I disable the blocking of proxy with parental control enabled I have connectivity.
    #567
    Glad everything worked out, and thanks for the update!
