Home › Forums › Parental Control › White List and Literal IP Addresses
  • #1967
    It is possible to create a whitelist for literal ip addresses?
    I need to block literal ip addresses but i want that a specific ip work. Like URLs.
    #1968
    Yes. You can list an IP address like 172.12.1.2, or a range in CIDR form, like 192.168.1.0/24. Alternatively, you can map the IP address to a name in the Hosts file (System Settings page).
    #1971
    1) What’s CIDR?
    2) 192.168.1.0/24. What mean “24”? Never heard nothing about it.
    3) I know what host file is and modify it much times. But, in this case, how i map the ip address to a name in the host file? Make me an example.
    #1976
    1). Check out this page: https://en.wikipedia.org/wiki/Classless_Inter-Domain_Routing
    2). Same as above.
    3). Look at the System Settings page, Hosts section.
